Infrastructure Map Server General
Member
owensr23
Message 1 of 4 (446 Views)
Accepted Solution
Fusion (FlexibleLayouts) gives configloaderror
446 Views, 3 Replies
06-19-2008 12:32 PM
I am using MapGuide Open Source Server with Autodesk MapGuide 2009 and I am testing my install using the samples.
For the Sheboygan sample I can view in the browser all of the samples in the Layers, but can't view any of the FlexibleLayouts.
When I view the flexible laysouts I get a box with the message "configloaderror".
Any ideas??
Member
owensr23
Message 2 of 4 (446 Views)
Re: Fusion (FlexibleLayouts) gives configloaderror
07-09-2008 06:20 AM in reply to: owensr23
Fixed it.
I had to add MIME type .json as application/json to the HTML/MIME types in IIIS
Member
ynking
Message 3 of 4 (446 Views)
08-10-2008 10:17 PM in reply to: owensr23
Thank you owensr23! You tip solved my problem.
Board Manager
Daniel.Du
Message 4 of 4 (364 Views)
10-15-2013 08:12 PM in reply to: owensr23
Reiterate this with detail:
     		- goto "Properties" of your fusion virtual directory in IIS  manager
     		- select "HTTP Headers" tab
     		- select "MIME Types..." button
     		- click "New" button
     		- enter:  		Extension:   .json
     			  		MIME type:   application/json
     	        - click "Ok"
Daniel Du
Developer Technical Services
Autodesk Developer Network
You are not logged in.
Announcements
Need installation help?
Ask the Community
