In MapGuide 2011 Enterpriese, we discovered a significant performance improvement of layer rendering/generation in the Flexview when the legend component is detached (i.e. no legend in the MapGuide view). I assume the performance hit occurs as the viewer is building the legend to support all of the themed objects. Is there a way to mitigate the perfrormance impact and still have a legend in the MapGuide view?
The problem is mainly 2 things:
If you know how to use git and how to build fusion, you can clone our git repo which has many performance improvements in the Legend widget and fixes many other usability problems. Works with MGE 2011.
https://github.com/jumpinjackie/fusion-multimap
These changes will eventually make it back into official fusion
- Jackie
