Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Flex Web Layout
2 REPLIES 2
896 Views, 2 Replies
Flex Web Layout
Hi Everyone,
Does anyone know how to change the colors of the flexible web templates?  Or can you point me in the direction of a training document or example?
Heidi
2 REPLIES 2
The easiest way to modify the style of the fusion template is to use a tool like Firebug or <insert developer tools of your web browser> to inspect the CSS of the element(s) in question that you want to modify. This will tell you 2 things:
 1. The CSS rules being used and their respective style settings (color, font, etc, etc)
 2. The stylesheet(s) where these rules are defined.
Then it's a case of editing the affected CSS stylesheets to produce the look that you are after.
- Jackie
Thanks Jackie... I am very new to all of this, so I will do some research and try to figure out how to do your suggestions, but thanks for pointing me in a direction!  I appriciaite it very much! Cheers
Spoiler
Smiley Happy
