Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Feature joins problem
5 REPLIES 5
sdalakov
332 Views, 5 Replies
I see this issue was commented before, but still I don't know if there is a solution. I want to connect an SDF data to an ACCESS table. Everything seems OK, but when trying to create a theme, based on a field from ACCESS, I get "Parameter was not found " error. I am using Studio 2007 with SP1 and MapGuide OS 1.1. Records in both sources are exactly matching.
5 REPLIES 5
dswilson
in reply to: sdalakov
What are the datatypes of the columns you are joining on? They have to match for the join to succeed. Does the join work correctly without theming? What datatype are you trying to theme on?
Dave
sdalakov
In SDF file key values are Char- they look like "100.01.56". In MS ACCESS they are defined as text. Seems that the join works (How to test ?) as I see in the list of fields, available for theming, all fields from ACCESS, I see no error messages. I attach here both SDF and ACCESS files - in case you are so kind (and have time of course) to have a look at.
sdalakov
I am trying to have a theme on based on a "long integer" field.
Regards
Stefan
I was able to theme this data without a problem. I used the SDF NAME field
and the Access table IMOT field as the key fields (the SDF KEY field did not
correlate with the Access data). I then themed on the long integer ADDRCODE
field from the Access database.
Do you have MapGuide Enterprise Service Pack 1 applied? I know there were
some problems with data extensions on non-integer keys prior to the service
pack.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
wrote in message news:5493824@discussion.autodesk.com...
sdalakov
Thanks a lot Andy
I switched to the right field and now its OK.
Sorry to spend your time on my faults
Regards
Stefan Dalakov
