Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
FDO provider for ODBC
3 REPLIES 3
341 Views, 3 Replies
I am having issues displaying Point (x,y) data from a SQL Server table on a layer.
I have tried the Autodesk FDO Provider for SQL Server but hadn’t been able to get a geometry to appear when I created the layer.
After that I had tried the OSGeo FDO provider for ODBC and connected to a SQL Server ODBC connection. This had given me the option to select my x & y values and the layer could successfully be created. The problem with this is that it is very slow (almost 1 min before the map will load now as opposed to the 10 seconds it used to take before the new layer was added).
Does anyone know why the ODBC connection is so slow, or of how I could use the Autodesk FDO provider for SQL Server instead (I would assume that I should be using this provider instead of the ODBC anyways)?
Billy
3 REPLIES 3
Hi
At least you got it to the stage where it would give you a map. I usually end up shutting Mapguide Studio off in task manager after 10 minutes of nothing.
As for the FDO provider - I've not got there yet but have managed to get somewhere with it see the following thread -
http://discussion.autodesk.com/thread.jspa?threadID=489744
Let us know if you get further.
James
Sorted
See following thread for solution/current progress -
http://discussion.autodesk.com/thread.jspa?messageID=5322328㙘
James
Your slow connection issue with odbc sources is _SIGNIFICANTLY_ reduced once you install service pack 1.
