Infrastructure Map Server General Discussion
New Member
bobbyh
Message 1 of 2 (654 Views)
Extending data store extents SQL 2008
654 Views, 1 Replies
12-03-2012 11:52 AM
When I created my database I set the Data Store Extents to an area Sufficient for my project, but the project has changed and I need to extend the area of the data store. Is there a way to change the Extents or does it matter if I’m outside of my data store extents. Thanks
Valued Mentor
jackie.ng
Message 2 of 2 (651 Views)
Re: Extending data store extents SQL 2008
12-03-2012 05:34 PM in reply to: bobbyh
Data store extents in SQL Server 2008 mainly affects the spatial indexes that gets created for geometry columns.
Is this a database with FDO metadata tables (they start with f_ ) or is it just a regular one?
If it's a regular database, just modify the bounds of the spatial index on that geometry column in question, otherwise if it has FDO metadata tables, you may have to also change the bounds in one of the f_ tables (it'd be the one relating to spatial contexts)
- Jackie
You are not logged in.
Ask the Community
