Infrastructure Map Server Developer
Valued Contributor
swimming123
Message 1 of 4 (1,062 Views)
Error for single layer size is 1 G
1062 Views, 3 Replies
05-23-2012 01:04 PM
Hi there,
When I load shp file which is bigger than several hundreds of MB, I found MapGuide always shows error. What solution for this issue? Thank you.
Valued Mentor
jackie.ng
Message 2 of 4 (1,058 Views)
Re: Error for single layer size is 1 G
05-23-2012 07:55 PM in reply to: swimming123
Are you using Load Procedures? They aren't really meant for loading files of this size.
For files of this size you should consider using aliases. Then you just create Feature Sources that point to your aliased SHP files instead.
- Jackie
Valued Contributor
swimming123
Message 3 of 4 (1,055 Views)
05-23-2012 09:24 PM in reply to: jackie.ng
What if I load the data to PostGIS first. Then I can create create Feature Source that point to the database?
Valued Mentor
jackie.ng
Message 4 of 4 (1,052 Views)
05-23-2012 10:32 PM in reply to: swimming123
Sure that works, whatever suits you. I am simply saying loading spatial data with Load Procedures is not suitable for really large files.
- Jackie
You are not logged in.
Ask the Community
