Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Error for single layer size is 1 G
3 REPLIES 3
swimming123
1301 Views, 3 Replies
Hi there,
When I load shp file which is bigger than several hundreds of MB, I found MapGuide always shows error. What solution for this issue? Thank you.
3 REPLIES 3
jackie.ng
in reply to: swimming123
Are you using Load Procedures? They aren't really meant for loading files of this size.
For files of this size you should consider using aliases. Then you just create Feature Sources that point to your aliased SHP files instead.
- Jackie
swimming123
in reply to: jackie.ng
What if I load the data to PostGIS first. Then I can create create Feature Source that point to the database?
jackie.ng
Sure that works, whatever suits you. I am simply saying loading spatial data with Load Procedures is not suitable for really large files.
- Jackie
