Hi Dave,
Thanks for the reply. We are still in the process of integrating MGE into our in-house application, so i have not spent too much time on this issue since i posted. However i did manage to subsequently generalize the data if i used the MapGuide 6.5 SDF Loader utility to first convert the SHP to SDF, and then load & generalize in MapGuide studio.
You might be correct about the invalid polygon data, i will perform more testing with alternative data sets and let you know if i find anything.
Majid
