Infrastructure Map Server Developer
Member
grand_duck
Message 1 of 4 (699 Views)
Error : DBEnv::open: DB_RUNRECOVERY
699 Views, 3 Replies
08-17-2011 01:46 AM
I received a stange error message, when i'm connecting to my site (running with Map Server 2012).
Error:
An exception occurred in DB component. DbEnv::smileysurprised:pen: DB_RUNRECOVERY: Fatal error, run database recovery.
Source:
OSGeo.MapGuide.MapGuideCommon.
Has someone already had this message ?
I don't know, what to do.
Best Regards.
Duck.
migueaguilera
Message 2 of 4 (667 Views)
Re: Error : DBEnv::open: DB_RUNRECOVERY
10-03-2011 04:46 AM in reply to: grand_duck
Hi Duck,
I have a server exactly with the same problem. In my case, the error occurs in a call to CreateSession.
Did you find any solution?
Member
grand_duck
Message 3 of 4 (657 Views)
10-04-2011 01:25 AM in reply to: migueaguilera
I've received a information from Autodesk:
Another suggestion you can have a try is : increate the value of SessionRepositoriesLimit
Please refer to the AIMS2012 readme doc -> Other Updates and Enhancements ->  Updates in serverconfig.ini.
SessionRepositoriesConfig          = FilePerSession
SessionRepositoriesLimit           = 200
Above ones are default setting for AIMS2012. Once the number of sessions reaches the Upper Limit, you may encounter the Fatal Error below.
For the moment, I changed the filePerSession by SingleFile, it seems to work, in my log, since 1 day, i don't found any DB_RUNRECOVERY.
But now, I have an another problem, the size of the repositorie increases quickly  :smileyfrustrated:
In my repositories, folder site, I see  log.0000x  created every 2 or 4 minutes, and i don't know why ??
Any ideas ?
migueaguilera
Message 4 of 4 (653 Views)
10-04-2011 02:55 AM in reply to: grand_duck
Thx for the info Duck.
I am performing several tests on my server. I'll tell you if I have good news and solve the problem.
You are not logged in.
Ask the Community
