Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Editing data online with MapGuide 2011
1 REPLY 1
studio
1310 Views, 1 Reply
Hi all,
it's weeks that I'm searching and try solutions proposed by many forums without find a way.
What I would like to do is allow the edits of my data (shape, table, etc) on line, by allowed user.
I've found a lesson that I attach, but I didn't understand very well how write the script, even to delete a simple feature.
I've read about GeoRest and his potential, very good, but I don't understand how use GeoRest to modify my features, and not only the features samples of Sheybogan.
http://code.google.com/p/georest/
Someone could help me in sonmeway?
I'm not very good in scripting.
Anyway, it's possible that with MGE2011, a licensed product that I've payed (or, better, my society have payed) it's not possible to manage this IMPORTANT tool?
Thanks very much for your attention and yours precious suggests.
Regards
1 REPLY 1
studio
in reply to: studio
The problem that now I have is insert a point in a existing feature source loaded into a map.
I've look in a lot of manuals and discussions, principally:
1-http://www.osgeo.org/files/mapguide/docs/webapi/d1/d60/class_mg_point.htm
2-http://svn.osgeo.org/mapguide/trunk/MgDev/Common/Geometry/AgfReaderWriter.h
3-http://augiru.augi.com/content/library/au07/data/paper/DE205-3.pdf
4-http://www.osgeo.org/pipermail/mapguide-users/2007-September/009023.html
But I'm not able to achieve that and I don't understand where is the problem.
Premises:
-the feature where I want to insert the new element came from a shpfile and it's stored inside the server, and is writable. The name of the layer is ""pti_23032"" and has 2 fields obligatory to modify: "Geometry" and "FeatId";
-I launch the script directly from the taskpane of my Ajax layout;
-I have access to the map as Administrator;
-I use MGE2011 in php/java
This is the code that I'm using to try to insert a "static" point to the map. It doesn't give me any error, but it doesn't create the point too! I attach it.
Thanks in advance for your help.
(I write here the "core" part of my code):
        //Specify the property values
        MgPropertyCollection properties = new MgPropertyCollection();
        MgAgfReaderWriter agfWriter = new MgAgfReaderWriter();
        //Proviamo a creare il punto acquisendo le coordinate:
        MgGeometryFactory geoFactory = new MgGeometryFactory();
                double x = Double.parseDouble(coods[0]);
                double y = Double.parseDouble(coods[1]);
                MgCoordinate coordinate = geoFactory.CreateCoordinateXY(x, y);
        MgPoint point = geoFactory.CreatePoint(coordinate);
        //Proviamo con queste righe prese dal forum salvato sul desktop...niente:
        MgWktReaderWriter wktReaderWriter = new MgWktReaderWriter();
        String pointstring = "POINT XY (" + Double.toString(x) + " " + Double.toString(y) + ")";
        MgGeometry geometry = (MgPoint) wktReaderWriter.Read(pointstring);
        MgByteReader geometryByteReader = agfWriter.Write(geometry);
        properties.Add(new MgGeometryProperty("Geometry", geometryByteReader));
        properties.Add(new MgInt32Property("FeatId", 6));
        MgInsertFeatures insertFeature1 = new MgInsertFeatures(layername, properties);
        MgFeatureCommandCollection commands = new MgFeatureCommandCollection();
        commands.Add(insertFeature1);
        //Per eseguire il comando--In realtà non serve ad un cazzo questa variabile "layer"...:
        MgLayer layer = (MgLayer)map.GetLayers().GetItem(layername);
        featureService.UpdateFeatures(fdo, commands, false);
