Hi, I would like know if exist the dobuleClick event in mapguide enterprise 2011 and if I can create a popup to click different elements.
Thanks.
There are several ways to do this, all of them require a bit of code:
If you are using FUSION/Flexible web Layouts, look into getting the x and y of where you double clicked and then selecting an object at that location. You can use openlayers to do the first part:
http://openlayers.org/dev/examples/click.html
http://openlayers.org/dev/examples/click-handler.html
If you are using AJAX/Basic Web Layouts, you can tie an event to the Map Frame and then use the ScreenToMapUnits in the Viewer Api (http://mapguide.osgeo.org/files/mapguide/docs/2.0/viewerapi.html)
In the end for both cases, you might want to use the MAPAGENT's QUERYMAPFEATURES to get the selected objects,
http://trac.osgeo.org/mapguide/wiki/HttpApi/RenderingService
regards
gordon
