Infrastructure Map Server General
s.klein
Message 1 of 5 (814 Views)
Digitizing Point in Flexible Layout and IE/FF
814 Views, 4 Replies
07-14-2011 03:06 AM
i want to use the digitizing php example of mapguide dev samples in AIMS 2012 with flexible layout in order to show XY-Coordinates of a point in task pane.
Finally i got it working, but just for flexible layout in internet explorer. When i want to use the widget in firefox 3.6 nothing happens. The standard browser of the company i'm working at is firefox 3.6 so it would be nice if anyone knows something about that problem.
the code i'm using:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
<title></title>
<script type="text/javascript" language="javascript" src="\\SRV05\C$\Programme\Autodesk\Autodesk Infrastructure Web Server Extension 2012\www\fusion\layers\MapGuide\MapGuideViewerApi.js"></script>
<script type="text/javascript">
function showCoordniate(geomText) {
document.getElementById('coordResult').innerHTML = geomText;
function OnDigitizePoint() {
//ClearDigitization();
DigitizePoint(OnPointDigitized)
function OnPointDigitized(point) {
var geomText = "X: " + point.X + "<br>" + "Y: " + point.Y;
showCoordniate(geomText);
</script>
</head>
<body>
<form id="form1" runat="server">
<div>
<input type="button" name="" value="Punkt" class="Ctrl" id="pntButton" onclick="OnDigitizePoint()"
style="width: 30%" />
<input type="button" name="" value="L&ouml;schen" class="Ctrl" id="clearButton" onclick="ClearDigitization()"
style="width: 35%" />
<hr />
Koordinaten:<br />
<div id="coordResult" style="height: 50; width: 275; overflow: scroll; color: InfoText">
</div>
</div>
</form>
</body>
</html>
I recognized that firefox 3.6 has problems with some kind of javascript, but i couldn't find a solution yet.
best regards,
S. Klein
Valued Mentor
Message 2 of 5 (808 Views)
Re: Digitizing Point in Flexible Layout and IE/FF
07-14-2011 06:51 PM in reply to: s.klein
Do you have firebug installed? Does it raise any errors?
- Jackie
s.klein
Message 3 of 5 (800 Views)
07-15-2011 04:23 AM in reply to: jackie.ng
Hello Jackie,
Firebug console prints this error:
DigitizePoint is not defined
[Bei diesem Fehler anhalten] DigitizePoint(OnPointDigitized)
(line 15 in XYTool.html)
But in IE8 the tool works..
S. Klein
Valued Mentor
Message 4 of 5 (792 Views)
07-17-2011 05:30 PM in reply to: s.klein
Does the Net tab in firebug show MapGuideViewerApi.js being successfully downloaded?
Somehow I get the feeling that Firefox doesn't like the fact that your MapGuideViewerApi.js is a UNC path.
- Jackie
s.klein
Message 5 of 5 (788 Views)
07-17-2011 11:15 PM in reply to: jackie.ng
Thanks Jackie, you are right. Firefox is unable to read the UNC path.
Just changed it and the tool works in firefox, too.
best regards,
S. Klein
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
