Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Custom Logo in Fusion Print Layout??
3 REPLIES 3
emluv
1048 Views, 3 Replies
I was wondering if anyone knows if it possible to add a custom logo in a print layout in a Fusion map? I have read that it is possible using Ajax or DWF viewers, I am just having a hard time finding out how to achieve this in Fusion. Please help:)
Thanks in advance!!
emluv
3 REPLIES 3
in reply to: emluv
Take a look at fusion "Print" widget where you installed the webserverextensions.
.../webserverextensions/www/fusion/widgets/Print/
There's a file "printablepage.templ" which contains the HTML for the printout. You can modify this to put in your custom logo.
Hope this helps!
Tags (3)
gluckett
Check out the Watermarking in AIMS 2012 (next version of MapGuide) - it is great for tagging all your maps with your corporate logo.
gordon
Daniel.Du
in reply to: gluckett
Agree with gordon about  the watermark of AIMS 2012 🙂
Check it out in the following webcast:
Video : Autodesk® Infrastructure Map Server 2012 API Webcast
Recorded version of the Autodesk® Infrastructure Map Server 2012 API webcast
View online | Download
Daniel Du
Developer Technical Services
Autodesk Developer Network
