Infrastructure Map Server General Discussion
ktamm
Message 1 of 4 (327 Views)
Creating connection in Studio 2012 to SQL database
327 Views, 3 Replies
04-11-2012 01:54 PM
We are able to setup a connection to our database. Where the problem is, is the field selected in the primary table and the field from the SDF are the same, but when we go to view the data joined we see the fileds from the SDF and only the field names from the table. Thedata does not populate the jioned fields.
Any suggestions?
Valued Mentor
gluckett
Message 2 of 4 (297 Views)
Re: Creating connection in Studio 2012 to SQL database
05-09-2012 06:12 PM in reply to: ktamm
i would make sure the column in the sdf is the exact type in sql sever, for example both INT
ktamm
Message 3 of 4 (292 Views)
05-10-2012 04:58 AM in reply to: ktamm
Thank you for the suggestion. Yes, we have made sure that this is the case for all fields.
Valued Mentor
gluckett
Message 4 of 4 (291 Views)
05-10-2012 05:24 AM in reply to: ktamm
i would recommend storing the spatial data in SQL server rather than SDF, then you can join in a view
You are not logged in.
Ask the Community
