Infrastructure Map Server Developer
New Member
Message 1 of 3 (743 Views)
Could not load MapguideDotNetApi in windows 2008 R2 64 bits
743 Views, 2 Replies
01-02-2013 03:22 AM
Hi
I installed first visual studio 2010, then installed AIMS2013 in a directory out of Program Files, followed all the instructions in http://download.autodesk.com/media/adn/AIMS2012_Webcast_English/AIMS2012_Webcast_English.html but didn't work. If netframework for web aplication is 3.5 i get could not load mapguidedotnetapi  earlier time error, i f i change to framework 4 i get could not load mapguidedotnetapi  format incorrect. AIMS2013Pool is configured to netframework 4 and 32 bits false.
I tried to find the solution in forums and internet, tried a lot of things but none work.
Could anyone tell me some clue or link, thank you, kind regards and happy new year
ADN Support Specialist
Message 2 of 3 (679 Views)
Re: Could not load MapguideDotNetApi in windows 2008 R2 64 bits
01-22-2013 09:49 PM in reply to: sbiot
If you followed the webcast but not succeeded, there may be some problem about the installation. Would you please check this post to check whether the installation is correct?
http://adndevblog.typepad.com/infrastructure/2012/04/install-autodesk-infrastructure-map-server-2013...
http://adndevblog.typepad.com/infrastructure/2012/07/installing-autodesk-infrastructure-map-server-2...
AIMS2013 uses .net framework 4.0.
You said that "install in a directory out of Program Files," is it permission problem? I have no idea only by this information, just guessing....
Daniel Du
Developer Technical Services
Autodesk Developer Network
New Member
Message 3 of 3 (674 Views)
01-23-2013 02:45 AM in reply to: sbiot
Hi Daniel
I can work perfectly in windows 7 32 bits, at this moment i'm installing on windows 7 64 bits to try if this is a problem on windows 2008 r2 64 Bits or if its a problem with 64 bits in general, i will post in a few hours the result of this installation
Thank you
Salvador Biot
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
