Infrastructure Map Server Developer
Valued Contributor
Message 1 of 4 (1,410 Views)
Could not load 'MapGuideDotNetApi' warning message
1410 Views, 3 Replies
09-17-2012 07:40 AM
When I start to do customization for AIMS using VS2010 .NET4.0, I copy the .dll file to my project folder, add reference to5 OSGeo***.dll files.  I got the warning messageis as follows:
Warning           C:\Altus\AltusWebMap\AltusWebMap\Default.aspx: ASP.NET runtime error: Could not load file or assembly 'MapGuideDotNetApi' or one of its dependencies. An attempt was made to load a program with an incorrect format. C:\Abc\AbcWebMap\AbcWebMap\Default.aspx         1          1          AbcWebMap
How to fix this?  Is this the problem that cause my redline not working? Thank you.
Valued Mentor
Message 2 of 4 (1,408 Views)
Re: Could not load 'MapGuideDotNetApi' warning message
09-17-2012 07:50 PM in reply to: swimming123
You need to make sure your IIS application pool assigned to your web application is running at the same bit-ness as your version of AIMS/MapGuide
- Jackie
Valued Contributor
Message 3 of 4 (1,402 Views)
09-18-2012 07:28 AM in reply to: jackie.ng
IIS Application pool is 64 bits, AIMS2013 is also 64bits, but my visual studio 2010 is 32 bits. It also matters,right?
Valued Mentor
Message 4 of 4 (1,396 Views)
09-18-2012 09:00 PM in reply to: swimming123
If you're debugging with Visual Studio's built-in web server (or IIS express), it's probably a 32-bit process, which is why it can't load your 64-bit MapGuide assemblies.
Try setting up a virtual directory in IIS for your MapGuide/AIMS application (assigned to the same application pool as MapGuide/AIMS) and open that virtual dir with Visual Studio (probably need UAC elevation). This should let you debug with IIS proper and have all the bitnesses be the same.
- Jackie
You are not logged in.
Ask the Community
