If you can't enumerate the tables (I've seen this happen with Oracle before
too), then you can most likely manually enter the table name and will still
be able to create a layer in
Author.
Andy
wrote in message news:5457168@discussion.autodesk.com...
has anyone succeeded in making a connection (through) odbc with Mysql and
MapGuide. I can see my tables popping up in MsAcces but when I use the same
connection in MapGuide I get the follwowing message:
Unable to enumerate the tables....
How come ? This shoul be possible, no ??
