Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Connecting to PostGIS 2.0
4 REPLIES 4
s.klein
759 Views, 4 Replies
i want to connect the AIMS 2012 to a PostgreSQL-DB with PostGIS 2.0 installed.
In Autodesk Infrastructure Studio i'm able to make a data connection so that the schema shows up in the preview.
When i create a layer, no geometry is shown up in the preview...
With Desktop-GIS like ArcMap or QGIS i can establish a connection without problems, so i think geometry columns are right in PostgreSQL 8.4/PostGIS 2.0.
Has anybody solved a problem like that yet?
SK
4 REPLIES 4
jackie.ng
in reply to: s.klein
The FDO provider that comes with AIMS 2012 does not support PostGIS 2.0
- Jackie
s.klein
in reply to: jackie.ng
sorry to hear that...
will fdo support postgis 2.0 in the nearer future?
pian2000
when you make the data connect can you view the attribute? and also when ceating for layer are you able to select the field?
s.klein
yes, i'm able to view the attributes and i can select the different attributes creating a layer... but the layer doesn't show up in the preview or weblayout. with postgis 1.5.3 it's working well.. i think aims can't handle the geometry cause it's stored in postgis 2.0 on an other way then in 1.5.3 and fdo doesn't support the postgis 2.0 geometry yet...
