Infrastructure Map Server General
s.klein
Message 1 of 5 (445 Views)
Connecting to PostGIS 2.0
445 Views, 4 Replies
01-26-2012 07:35 AM
i want to connect the AIMS 2012 to a PostgreSQL-DB with PostGIS 2.0 installed.
In Autodesk Infrastructure Studio i'm able to make a data connection so that the schema shows up in the preview.
When i create a layer, no geometry is shown up in the preview...
With Desktop-GIS like ArcMap or QGIS i can establish a connection without problems, so i think geometry columns are right in PostgreSQL 8.4/PostGIS 2.0.
Has anybody solved a problem like that yet?
SK
Valued Mentor
Message 2 of 5 (437 Views)
Re: Connecting to PostGIS 2.0
01-26-2012 05:43 PM in reply to: s.klein
The FDO provider that comes with AIMS 2012 does not support PostGIS 2.0
- Jackie
s.klein
Message 3 of 5 (433 Views)
01-26-2012 10:43 PM in reply to: jackie.ng
sorry to hear that...
will fdo support postgis 2.0 in the nearer future?
Active Member
pian2000
Message 4 of 5 (384 Views)
03-19-2012 01:16 AM in reply to: s.klein
when you make the data connect can you view the attribute? and also when ceating for layer are you able to select the field?
s.klein
Message 5 of 5 (381 Views)
03-19-2012 02:41 AM in reply to: s.klein
yes, i'm able to view the attributes and i can select the different attributes creating a layer... but the layer doesn't show up in the preview or weblayout. with postgis 1.5.3 it's working well.. i think aims can't handle the geometry cause it's stored in postgis 2.0 on an other way then in 1.5.3 and fdo doesn't support the postgis 2.0 geometry yet...
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
