Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Collapse layergroup
4 REPLIES 4
veillout
295 Views, 4 Replies
Collapse layergroup
I just want to collapse all layer groups at the start application. I use this function in OnViewChanged() :
var map = GetMap();
var myLayerGroups = map.getMapLayerGroups();
for(var i=0; i < myLayerGroups.size(); i++)
var myLayerGroup = myLayerGroups.item(i);
myLayerGroup.collapse();
It works well but when I make zoom it collapses my group again...
How can I do to collapse just at start?
thanks for helps.
Yan
4 REPLIES 4
in reply to: veillout
Use the onMapLoaded event instead.
Andy
wrote in message news:5619097@discussion.autodesk.com...
var map = GetMap();
thanks for helps.
Yan
veillout
Have you got an example or a web site where I can find it?
There's information and examples in the API Help documentation. It looks
like you have your functionality coded correctly, but your question was to
how to execute it only when the map loads. In that case, use the
onMapLoaded event just like you are using onViewChanged. Keep in mind that
as the user moves around the map and the legend refreshes, the legened tries
to re-expand so you will probably have to use onViewChanged in addition.
Andy
wrote in message news:5625819@discussion.autodesk.com...
bjeffers
Where would you put this code? In a PHP? legend.php? Message was edited by: bjeffers
