I am new to MapGuide and Infrastructure Map Server. I have loaded Infrastructure Studio 2012 on a server that has OSGeo MapGuide running. When I try to connect to an SDF file that I exported from AutoCAD Map 3D by clicking the load resources button in step three of the dialog, I get: "Could not load file or assembly 'C:\Documents and Settings\ttrue\Local Settings\Temp\1\SdfLoadProcedure\schema.xml' or one of its dependencies. The system could not find the file specified" I have looked and the SdfLoadProcedure doesn't exist. Do I need to create this folder and file or should it already exist?
