Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Can I change ApplicationDefinition based on log in client's Id
3 REPLIES 3
swimming123
804 Views, 3 Replies
In order to show different spatial data type to different clients; Can I dynamically (program) to create a fusion Application Definition? I really need this function works.
3 REPLIES 3
jackie.ng
in reply to: swimming123
An ApplicationDefinition is just an XML document pointed to by a resource id.
Both of which you can customize and/or override before the Fusion viewer ever gets its hands on it.
So you would build the specific ApplicationDefinition XML document based on your client's id, save it out into a session-based resource id, and feed that resource id into your Fusion template URL so it gets initialized with your client-specific ApplicationDefinition
- Jackie
swimming123
in reply to: jackie.ng
Thank you very much, Jackie.
swimming123
It's a very good idea. But I cannot find the where is the fusion Application Definition file stored, or where is my layout folder is when I create it using Studio or Maestro. Thank you.
