Infrastructure Map Server Developer
Member
ralfzenklusen
Message 1 of 4 (1,466 Views)
Bing Maps Mobile Viewer
1466 Views, 3 Replies
10-11-2011 07:53 AM
Hi
I work with AIMS2012 and installed mobile viewer. Now I can display the map (sdf files) but base layers for example Google Maps or Bing Maps are not visible. How or where can I define what base layers are visible in the mobile viewer?
Best and thx
Valued Mentor
jackie.ng
Message 2 of 4 (1,462 Views)
Re: Bing Maps Mobile Viewer
10-11-2011 09:19 PM in reply to: ralfzenklusen
I did take a look at the Mobile Viewer when AIMS 2012 was in beta, and the documentation at that point stated that if you want to show commerical layer types, you pass in the layer types through the baselayers query string parameter, and a dot-separated list of layer types
baselayers=[osm.[google.[yahoo.[bing]]]]
I don't know if this has changed for the final release.
- Jackie
Member
ralfzenklusen
Message 3 of 4 (1,459 Views)
10-11-2011 11:46 PM in reply to: jackie.ng
Hi Jackie
Below you can find the code from the index.html file (method initializeMobileViewer). The main problem is that I don't know where and how I have to set the variable baseLayers = 1.
var baseLayers = mobileViewer.getQueryParam('baselayers');
        if(baseLayers != null)
            baseLayers = baseLayers.toLowerCase();
            if(baseLayers.indexOf('google') != -1)
                options.googleAPIKey = 'ABQIAAAATNYJBHVIVaSq5AtEw2iEHxSJCEhdEXSl6Vs0dgfLrrKbPf3nZhSDk_cegF7b2IlTWrLNLOXKqNVJqg';
            if(baseLayers.indexOf('bing') != -1)
                options.bingAPI = 'true';
            if(baseLayers.indexOf('yahoo') != -1)
                options.yahooAPIKey = 'XnPi3lbV34HwYXZ3h3peTvVs.dGoQtkMv1f.v9ztVLy9VWbzqhZM.vcFmwrMjpsX1lvpV4w-';
            if(baseLayers.indexOf('osm') != -1)
                options.osmAPI = "true";
Thx
Valued Mentor
jackie.ng
Message 4 of 4 (1,450 Views)
10-12-2011 06:05 PM in reply to: ralfzenklusen
You don't.
You pass that parameter as part of the URL like so:
index.html?baselayers=[osm.[google.[yahoo.[bing]]]]
- Jackie
You are not logged in.
Ask the Community
