Issue: Unless the user picks "dead center" of the point, an error is returned and the map has a continuous "Busy" state.
Level: Crashes and requires re-start of web page.
Steps to Reproduce:
1. Using Sheboygan data from (http://download.osgeo.org/mapguide/releases/2.0.0/samples/Sheboygan.mgp) load the package into AIMS
2. Add Trees to map
3. Open any of the flexible web layouts (i.e. Aqua)
4. Pick a point, or just the edge of a point.
5. Error is produced and AIMS is now permanently "busy"
Unfortunately no fix released from Autodesk yet.
I did have some luck with grabbing the DLLs from MapGuide 2.6 (into C:\Program Files\Autodesk\Autodesk Infrastructure Map Server 2015\Bin)
and the MapGuide 2.6 Fusion files into (C:\Program Files\Autodesk\Autodesk Infrastructure Web Server Extension 2015\www\fusion)
That is a bit drastic but it got me running again without the pick a point crash that is currently happening in AIMS 2015
