Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Autodesk Infrastructure Studio 2012 vs 2014 vs 2015
0 REPLIES 0
Message 1 of 1
507 Views, 0 Replies
Im having problem creating Theme Layer in Autodesk Infrastructure Studio 2012 and 2015.
From the image above, im using the same dataset to create theme layer on different version of Studio.
Fyi, property selected consist same values which is 'test link'.
It works perfectly fine in Infra Studio 2014 where min value and max value = 'test link' and number of rules = 1.
But in Infra Studio 2012, the number of rules = the total of spatial data available although the value of the property is the same. i try to fix it by installing service pack but nothing works.
in Infra Studio 2015, min value, max value and number of rules does not show any value. OK button not even enable.
Not sure what's wrong.
-nick-
0 REPLIES 0
