Infrastructure Map Server General Discussion
ericsn.tang
Message 11 of 17 (233 Views)
Re: Autodesk Infrastructure GeoREST Extension 2012 - 64BIT
01-29-2014 08:10 PM in reply to: gluckett
Eventually it works! The map can be generated, but it is only support the feature type which is the polygon type! Is it true? Once I used the point feature, the message "Failed to retrieve message for "MgInvalidArgumentException". [SETVIEWSCALE] = "0" Failed to retrieve message for "MgValueCannotBeLessThanOrEqualToZero"." will prompt.
Active Member
reno.sun.gis
Message 12 of 17 (169 Views)
03-31-2014 03:11 PM in reply to: gluckett
Hi :smileyhappy:
I don't know if you noticed that GeoRest actually generate PNG/JPEG images slowly. It took about 30 secs to generate every PNG images in my case.
Therefore, you will not see the images showed up properly on your GeoRest many/single template pages.
In my opinion, you can probably use C# or other programming languages to create a small GeoRest images pre-geneartion application to generate all the images that you need.
The code will be very similar as following:
int start = Int32.Parse(StarttextBox.Text);
int end = Int32.Parse(EndtextBox.Text);
for (int i = start; i <= end; i++)
string sourceUrl = @"http://localhost/rest/data/test/" + i.ToString() + ".png";
string localPath = @"C:\inetpub\wwwroot\test\png\" + i.ToString() + ".png";
byte[] imageBytes;
HttpWebRequest imageRequest = (HttpWebRequest)WebRequest.Create(sourceUrl);
WebResponse imageResponse = imageRequest.GetResponse();
Stream responseStream = imageResponse.GetResponseStream();
using (BinaryReader br = new BinaryReader(responseStream))
imageBytes = br.ReadBytes(500000);
br.Close();
responseStream.Close();
imageResponse.Close();
FileStream fs = new FileStream(localPath, FileMode.Create);
BinaryWriter bw = new BinaryWriter(fs);
try
bw.Write(imageBytes);
finally
fs.Close();
bw.Close();
Hope that will help you :smileyhappy:
Valued Mentor
gluckett
Message 13 of 17 (151 Views)
04-04-2014 09:20 AM in reply to: reno.sun.gis
For those stuggling with the GeoRest bundled with AIMS, I also would recommend the new mapguide-rest project started by Jackie Ng.
It is dead easy to set up and works really quickly.
It uses AIMS 100% (sorry no direct connect to FDO) - but it is very slick and faster than GeoREST.
http://themapguyde.blogspot.ca/2014/02/introducing-mapguide-rest-new-rest.html
https://github.com/jumpinjackie/mapguide-rest
Valued Mentor
jackie.ng
Message 14 of 17 (138 Views)
04-06-2014 06:14 PM in reply to: ericsn.tang
Before anybody gets too excited, mapguide-rest is not production-ready yet.
There's still some security hardening to be done before I can safely say that you can put this to production use.
Sure, download the current release to have a play around and see what it can do, but I strongly discourage production deployment at this point in time, especially on public-facing MapGuide/AIMS installations.
- Jackie
Valued Mentor
gluckett
Message 15 of 17 (120 Views)
04-10-2014 06:19 AM in reply to: jackie.ng
Still, your prototype ("Alpha") is very promising and slick. We should all keep an eye on the mapguide-rest project.
ericsn.tang
Message 16 of 17 (66 Views)
06-04-2014 12:10 AM in reply to: gluckett
Is there someone try to use the post/ put of georest? I want to update/ create a new entries for the specific SDF connection. How can I generate the SHPGEOM from the fusion viewer? :smileyhappy:
<Name>SHPGEOM</Name>
<Value>
POLYGON ((-87.750602148149582 43.772512943108723, -87.750820980626941 43.772509600594994,
-87.751112034446564 43.772505154303111, -87.751191267124568 43.772701180970984, -87.750821769925366
43.772706826945878, -87.750681379906538 43.77270897188734, -87.750664555803112 43.772667347110961,
-87.750602148149582 43.772512943108723))
Valued Mentor
gluckett
Message 17 of 17 (63 Views)
06-04-2014 06:26 AM in reply to: ericsn.tang
Check out the classic GeoREST (Comes with AIMS) how to put post and get data to a SDF or SHP.
He is my presentation at Autodesk University.
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2013/infrastructure-map-server/gs15...
You are not logged in.
Ask the Community
