Im running a PC with AutoCad Map 3D 2010 on windows xp SP3 32 bit OS.
The application was working. User called and stated she is now getting the error below and has not installed any updates or software.
Im getting this error below.
Unable to run AutoCAD. This may be sue to one of the following reasons:
1) The version of AutoCAD was not installed properly. In this case, you may wish to reinstall AutoCAD.
2) You do not have sufficient rights to run AutoCAD
Ive reinstalled the software and Im admin of the box.
Any suggestions would be helpful.
FATAL ERROR:Unhandled Access Violation Reading 0x1d93758 Exception at 51513eh
Any suggestions or information you need, please ask.
