Corey,
Is the .MWX being edited on the same machine as the Author?
If not, it may be that access to the location from which the Author opened
the file has been lost. Attempting to save back to the 'non-existent'
location causes the Author to hang. This also happens with .MWF files.
Chris L. Amos
Quality Engineering Autodesk MapGuide
"CLydstone" wrote in message
news:19154949.1080849525274.JavaMail.jive@jiveforum1.autodesk.com...
> After upgrading to version 6.3 (from 6.0), I have been having an
intermittent problem with MG Author. When I try to save a MWX after making
some changes I frequently get an error message saying that access to the
file was denied. After the message is displayed Author goes into a busy
state and hangs, I then have to end Author manually. Has this happened to
anyone else, is there something I can do to prevent this? Thanks.
> Corey
