Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Adding Reports via API
2 REPLIES 2
sphilson
227 Views, 2 Replies
Is it possible via the API to add a report to a mwf file?
2 REPLIES 2
in reply to: sphilson
With MapGuide R6, you can use the Dynamic Authoring Toolkit to add/change/delete reports to a MWF file. For more info on how to use Dynamic Authoring Toolkit, refer to Dynamic Authoring Toolkit Developer's Guide that's available online at http://www3.autodesk.com/adsk/item/0,,937397-123112,00.html#section8
Ken
zaremm
The MapGuide Viewer API allows for calling an existing report (invoking a report request), but does not allows for creating & configuring a new report. As mentioned above- the Dynamic Authoring Toolkit would allow for that.
Matt Z.
