Those names are just the default names generated by MapGuide Studio / AutoCAD Map when you create new Feature Sources.
To get the name of the geometry property:
Get the matching class definition (MgClassDefinition) object for that feature source using MgFeatureService::GetClassDefinition
Calling GetDefaultGeometryPropertyName() on that class definition will give you the name of the geometry property.
- Jackie
http://themapguyde.blogspot.com
http://au.linkedin.com/in/jackieng
