I believe I have found a bug, or at the very least something extremely annoying. (a bug) The bug is this,
I have an SDF with more than one property within it. If I create a themed layer using that SDF and in the expression builder I say as a condition to show both properties and a attribute of each property as an output the layer will only return the first property in the expression.
For example my layer defined with the expression would look like this:
AUTOCAD_LAYER_MAPPER = 'PRIMARY_HWY' OR AUTOCAD_LAYER = 'PRIMARY_HWY_GP_CITY'
Where AUTOCAD_LAYER_MAPPER and AUTOCAD_LAYER are two available properties listed in the SDF . The result of that statement will return only the first value AUTOCAD_LAYER_MAPPER = 'PRIMARY_HWY'. If I reverse those two values, then again the first one listed will appear in the layer and the other will not.
If I create two seperate theme conditions using the AUTOCAD_LAYER_MAPPER = 'PRIMARY_HWY' on it's own theme condition and the other on it's own theme condition then they both appear. However, i should not have to do that.
This is a bug IMO.
