Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
AIMS 2014 service pack coming soon?
3 REPLIES 3
frosty1_4me
506 Views, 3 Replies
Curious as to when a service pack will be released for AIMS 2014.   Improvements and bug fixes are something AIMS could benefit from.
3 REPLIES 3
gluckett
in reply to: frosty1_4me
If you need to load DWG with Object Data or Link Template this fixes this issue:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21891276&linkID=9242179
frosty1_4me
in reply to: gluckett
That's great for the OD, but loading the dwg's don't work as they lose all the styling which is what is really required from a dwg, otherwise you might as well use an SDF or DWF (barf)
gluckett
Yes, the old MapGuide (6.5 and older) had two DWG options:
It converted the DWG into Vector (with LT or OD attributes) OR streamed the DWG as-is graphically - almost like the DWF.
It worked well - I wish AIMS had this same two options.
