Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
AIMS 2013 getSessionID API change?
1 REPLY 1
gluckett
1366 Views, 1 Reply
Ok I found a difference between AIMS 2012 and AIMS 2013
With 2012 you get the session id with Fusion like this:
	var mapWidget =Fusion.getWidgetById('Map');
 	var SESSION = mapWidget.getSessionID();
 	var MAPNAME = mapWidget.getMapName();
BUT with AIMS 2013 I have to do this:
	var mapWidget =Fusion.getWidgetById('Map').aMaps[0];
So a lot of code changes and searches and replaces....
1 REPLY 1
Daniel.Du
in reply to: gluckett
Yes, I notice getSessionID() is removed from  Fusion.Widget.Map of AIMS 2013. Thank you for raising this!
The code comment of AIMS 2012 saying :
getSessionID: function() {
        //TODO: what is the mapname in the case of multiple map layer objects?
        //just return baselayer session ID for now
        return this.aMaps[0].getSessionID();
so it seems that it was a temparary implementation is AIMS2012.  I am checking with development team for the exact reason of this change. I will update this thread when I get a response.
Daniel Du
Developer Technical Services
Autodesk Developer Network
