Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
AIMS 2013 REDLINE
5 REPLIES 5
swimming123
967 Views, 5 Replies
AIMS 2013 REDLINE
I found redline tool in AIMS2013 is pretty hard to use. First step is "Manage Redline", just let you save a layer and add to map, don't do not digitization; second step to "edit redline", then it start to Digitization, unfortunately it always ask you to add the text name for the digitized feature, then the map auto-refresh, all the digitied feature will lost agian. Am I doing the correct way? Anybody tried this tool? Thank you.
5 REPLIES 5
jackie.ng
in reply to: swimming123
Your aforementioned usability problems were addressed, but the updated widget didn't make it into AIMS 2013
- Jackie
swimming123
in reply to: jackie.ng
Can I download the updated widget and put it into AIMS2013?
jackie.ng
You could do that, but you would need to also rebuild the fusionSF-compressed.js as well, so it has the updated widget code included.
- Jackie
swimming123
Where can I download, any link? By the way, how to rebuild the fusionSF-compressed.js?  Thank you.
swimming123
I found the problem is because I use BaseLayerGroup. If I don't put layers in BaseLayerGroup, all functions work fine. But I really wish I can use BaseLayerGroup meanwhile Redline, Buffer functions all work. This way, the web can render faster.
