Hi all,
I'm having difficulty when using Feature Label function in AIMS 2013 where the label will show as "Text" in the map preview although there is no info on the selected feature. see figure below - AIMS 2013)
It works find in AIMS 2012 where it should show any label on the selected feature because there is no info. (See figure below - AIMS 2012)
i'm not sure how to explain this but i hope u guyz could understand.
thx
-Nik-
Solved by nik.mazreen. Go to Solution.
