First bug:
GET http://khm1.googleapis.com/kh?v=151&hl=en-US&x=16385&y=16384&z=15&token=77969 404 (Not Found)
Javascript Errors when using AIMS 2015 with Flexible Web Layouts with any Google or Bing layers
Second Bug:
In flexible web layouts, when selecting any single Point below 1:1100 scale, Fusion gives an error such as the following:
Fusion Error: WARNING: Exception occurred in AJAX callback. Message: Cannot read property 'focus' of undefined Location: undefined (undefined) Response: {"hasSelection":true,"extents":{},"layers":["Lots"],"Lots":{"featureCount":1}}
The browser then hangs due to "busy" state with AIMS...
It is great that with the new commercial layers that you can zoom in below the standard 1:1150 etc, but I think that new change caused the second bug.
It is probably related to this patch.: http://trac.osgeo.org/mapguide/attachment/ticket/2459/2459.patch
hopefully this can be put out in a service pack. If you can't select points it makes for "show stopper" of a bug.
With respect to Bug #1, I get the same errors but only if any of the Google layers are selected with the exception of the "Street" option. If the only selected Google option is "Street", then I can mix and match Bing, Open Streets etc without issue.
I can also confirm Bug #2.
