InfraWorks General
Valued Mentor
Message 1 of 3 (595 Views)
water areas within designed dams and channels
595 Views, 2 Replies
02-19-2013 02:34 AM
AIM 2013
How do you present designed dams and water channels in AIM?
In my first attempt I am only dealing with dams.
The dams have been designed in C3D using C3D grading.
I opted not to use IMX to represent the damns as I wanted to make a clear difference between the Terrain and the dam regions.
Instead, I used FBX. Imported into AIM as Buildings.
I think this is already wrong as AIM seems to avoid buidlings when creating water areas manually.
What AIM object do I use to represent dams and channels - needing to contain water areas?
Thx,
Kevin.
Valued Mentor
Message 2 of 3 (592 Views)
Re: water areas within designed dams and channels
02-19-2013 03:08 AM in reply to: kevin.barnett
oops ... it was the holes in the NGL surface that caused the 'non-water' problem.. I made holes where the dams are..
now I filled in the holes and the water is working correctly .. even with the dams represented as buildings..
almost there ..
Valued Mentor
Message 3 of 3 (579 Views)
02-19-2013 04:29 AM in reply to: kevin.barnett
the solution is to make deep holes in the terrain source data, way deeper than the designed surface..
: ) I now have instant cool water waves - thank you Autodesk : )
You are not logged in.
Ask the Community
