InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
story board
5 REPLIES 5
1569 Views, 5 Replies
story board
I'm trying to create a fly over presentation.  Im' not able to get a smooth transition from one key frame to the next.  I started with "Add Camera Path Animation".  I have tried the 3 different options for interpolation from one frame to the next.  But it doesn't seem to change the end result.  I also tried all the different zoom and orbits.  but I am just looking for a smooth fly over from frame to frame.  Any suggestions??
Julie Turner-Mitchell
5 REPLIES 5
ToddRogers-WPM
I think I might know what you're doing wrong.  First, you will need to create a camera path.
Once you have created the camera path, pan and zoom to the next "shot".  Then click to add a Keyframe...
Then do the same procedure.  You keep adding keyframes, not sequences (camera paths).
Todd Rogers
I'm pretty sure that's what I did.
thanks, I finally see the difference between the two.
neilyj666
in reply to: ToddRogers-WPM
I'd been wondering how to do this - pretty easy when you know how...:)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Thanks for your instruction.  Do you know of anywhere there is  detailed instructions on storyboards and what the difference is between all the animation options???  I have figured out the geneal info, but would love to make a really cool video that doesn't look like an amateur did it.  Thanks in advance!!
Julie
Rail Community
