InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
recommended video settings for high quality output
14 REPLIES 14
Message 1 of 15
JamesMaeding
5695 Views, 14 Replies
What settings should I use for high quality video output?
I have tried a few, but want to see what others have found.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
14 REPLIES 14
Message 2 of 15
If you use Windows Media output, click the properties button and change the bit rate to 8500.
Todd Rogers
Message 3 of 15
JamesMaeding
in reply to: JamesMaeding
thats what we tried before, worked pretty well actually.
Just wanted to see if there was a "sweetest" spot.
The showmotion feature is nicely made, good job by Autodesk on keeping it simple, compact, yet with details we need.
thx
Message 4 of 15
It's actually much more complex in R2.  It takes some getting used to, but it's really cool because you can add captions and different story boards to it.
Todd Rogers
Message 5 of 15
My Captions are getting squished...dont know why.
Message 6 of 15
Should have a resolution set to 1920 x 1200.
Todd Rogers
Message 7 of 15
OK - Thanks - I will try that. I used the1920x1440 or something like that.
Cheers,
Thomas
Message 8 of 15
do you really need to go beyond 1080 HD?
If we are talking IMAX, how about 4x that?
Have you tried what you suggest for large models?
Message 9 of 15
1080 HD is a bitrate of 10400, a framerate of 24, and resolution of 1920 x 1200.
Todd Rogers
Message 10 of 15
1080 is 1080 pixels vertically, not 1200.
I'm just wondering why you suggest something over HD, do you find it looks better on HD screens?
Message 11 of 15
Yes you are correct, 1920 x 1080, but most computer monitors use the 1920 x 1200 which the video fits best on most computer monitors.
Todd Rogers
Message 12 of 15
I use Camtasia Studio for editing my videos - just learning actually. So I discovered that Camtasia does not like videos that are larger than 1280x1024. So back to the drawing board and export a smaller video for that. Just an FYI...
Thomas
Message 13 of 15
I use Camtasia. Create a custom size. Works great for me. I created a custom size of 1920 x 1080.
Todd Rogers
Message 14 of 15
I get an out of memory error...I have a pretty good setup here. Maybe I'm missing something.
Thomas
Message 15 of 15
kgrover
Has anyone had any luck to render a video with a point cloud?? I have tried many different combinations of settings, but it only creates a strip of video in teh center of the screen, and doesn't render the full view.
Kevin
Rail Community
