Hi
Once I have drawn coverages within InfraWorks, and assign the 3d models to Rule style and set Object Spacing to 100m, it is fine within Infraworks. But when I would like to export them to fbx format and there are no 3d models in the drawn coverages.
If I loaded shape file into infraworks as coverages and set rule style to 3d models, when I exported into fbx format, it works perfect.
What's wrong with it?
How can I convert drawn coverages as Data Sources?
Tom
I believe you can export that coverage to an IMX file and then re-import it into your model.
