is there any any way to change the density of the trees in tree group? or set the density of for example 1 tree per 3 square meter?
thanks
Hi Piotr,
In Infrastructure Modeler 2012, it is not possible to change the tree density. We are considering adding such a feature in the future.
If you want more dense tree areas, many of us approximate this by sketching tree polygons repeatedly on top of each other.
Chris
Cheers, also found later that day if doing a slow double click on a tree in the 'forest' the slider would appear and I was able to edit the whole tree group.
