InfraWorks General
Message 1 of 5 (828 Views)
coordinate system
828 Views, 4 Replies
10-24-2012 01:37 AM
Can you please tell how to change the coordinate system of the model in the project? Is it possible? Originally been set incorrectly.
Employee
Message 2 of 5 (818 Views)
Re: coordinate system
10-24-2012 04:04 AM in reply to: RavchukNA
you can only set the CS of the model during the creation. However changing the Model CS during "New" and using a projected coordinate system will not increase speed or accuracy, or make it possible to import more data, but it will limit the possible size of your model. The only reason to change the default settings is if you plan to work directly with the model's SQLite file outside Autodesk Infrastructure Modeler.
The User CS is used to display coordinates in the status bar and for any other CS display. You can set that to any coordinate system at any time without affecting how data is stored in the GIS database or displayed in the 3D model.
Heiko Meyerdirks
Engineering Manager
Autodesk IPG ICP InfraWorks
Employee
Message 3 of 5 (817 Views)
10-24-2012 04:07 AM in reply to: heiko.meyerdirks
You do not need to change the CS even when all your data is stored in one different CS. Projecting to LL always does work lossless for AIM. In many cases, you will also be successful re-projecting data in an individual CS in AIM. But this depends on the CS you selected and on the input data as many CS have just a specific area which is valid. So here, you will face unexpected behavior in some cases.
You also cannot change the model CS afterwards, so once you run into such an problem, rebuilding the model may become necessary. Therefore we suggest not to change LL if you have no intend to work on the SQLite file directly or of cause policies. That way you will stay flexible for whatever data you will add in future.
Heiko Meyerdirks
Engineering Manager
Message 4 of 5 (812 Views)
10-24-2012 04:24 AM in reply to: heiko.meyerdirks
When I try to publish a part of the project, I get the following error
These boundaries do not overlap with the defined boundaries of the coordinate system of the model. Bounds must be in the following range:
[82418.6; -928 519] - [917 581; 9.99796e +06]
How to cure it?
Employee
Message 5 of 5 (795 Views)
10-25-2012 06:23 AM in reply to: RavchukNA
Looking at your numbers I assume you model has not been created in LL? If that is true this may exactly be an error due to the limited valid size of a projected CS. How have you chosen the extent of the scenario manually by the extent tool or chosen the entire model? If the latter you can try to publish a smaller area you are interested so you may get around rebuilding the model.
Heiko Meyerdirks
Engineering Manager
You are not logged in.
Ask the Community
