Still stuggling on with Infraworks for windfarm visuals and have hit another issue:
When viewed from a distance all the turbines disappear and only reappear as I zoom nearer to them - is this visibility/invisibility controlled by a setting somewhere?
Solved by neilyj666. Go to Solution.
That's pretty typical for complex 3D models. However, there are some settings to try. Turn off Ambient Occlusion, turn off realistic water, turn off realistic water and turn on show backfaces.
Turning off LOD for the Turbines seems to have done the trick
