Still stuggling on with Infraworks for windfarm visuals and have hit another issue:
When viewed from a distance all the turbines disappear and only reappear as I zoom nearer to them - is this visibility/invisibility controlled by a setting somewhere?
Solved by neilyj666. Go to Solution.
Turning off LOD for the Turbines seems to have done the trick
