InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
What's the trick to getting IMX pipes in
1 REPLY 1
442 Views, 1 Reply
What's the trick to getting IMX pipes from C3D to come in with correct structure sizes and inverts?   Appears all manholes are the same size and all pipe are the same size and all inverts are the same elevations? If there a trick or setting on the import process to get IMX to use the correct data?
Help and tutorials don't say much.
Bill Neuhauser
Tags (1)
1 REPLY 1
Figured it out, turns out when you import from .IMX it defaults to metric.  So when you do the data source configuration make sure to change your uints on the Size settikngs  X/Y to ft.
Bill
Rail Community
