InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Template in Infraworks
1 REPLY 1
678 Views, 1 Reply
I am playing with a bit with Infraworks. For preparing fast presentations found out that collection of symbols, road styles, materials ... are not organized in a way to use it fast. So I managed my own styles (basically copy and change the name to be on the top of the list). For some items through style palette I created new folders with most frequently used symbols. With that I decrease searching through long lists of symbols and items.
But I had opinion that I am doing the reorganization on the application level, but it is not the case. Everything what I did is saved on model base. Means, when I started new model, everything is again default.
The next idea is to find if there is any kind of template, but cannot find. So the only way, what I found for a while is to preserve the empty model with small customization, open it, use command for copying the opened model to the other one (kind of save as) and to continue work.
Does anybody found the other way of working?
Drazen
1 REPLY 1
tcorey
Once you've made the new styles in a project, you can go to the Style tab and export those styles to a file. Once back in another project, those styles can be imported from the .json file that was made when you exported.
I agree, the process could be better, but it's not too big a deal.
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Rail Community
