InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Storyboards and Proposals
7 REPLIES 7
Message 1 of 8
mshoffman
747 Views, 7 Replies
Im still in the learning process, however I am trying to figure out how to show different proposals with storyboards.  On the ipad you can view storyboards and layers, if i could assign proposals to storyboards that would be ideal.  Any thoughts?
7 REPLIES 7
Message 2 of 8
ToddRogers-WPM
in reply to: mshoffman
That can be done by creating different Scenarios.  Under the Present tab, it's the first button.
Todd Rogers
BIM Manager
Blog | Twitter | LinkedIn
Message 3 of 8
mshoffman
in reply to: ToddRogers-WPM
I can create a scenario, however where do you specify which proposal you want to use in the scenario?
Message 4 of 8
ToddRogers-WPM
Good question.  I see where you can link it to the Storyboard.  Konstantin (Autodesk), any suggestions?
Todd Rogers
BIM Manager
Message 5 of 8
eric.fain
When you are publishing a Scenario, the active Proposal is used to create it. There is no direct link to the Proposal from the Scenario itself. If you need to tie together a Proposal and a Scenario use a naming convention to do this.
Message 6 of 8
ToddRogers-WPM
in reply to: eric.fain
Wish list?
Todd Rogers
BIM Manager
Message 7 of 8
mshoffman
I concur.  Having some checkboxes to include proposals like you can with storyboards when publishing would be nice.
Message 8 of 8
mshoffman
On second thought, Having to publish multiple scenarios to see different proposals is a lot considering each scenario is a separate file on the ipad's application.  What would be better is to be able to specify the proposal you want to see on the story board.
Rail Community
