Im still in the learning process, however I am trying to figure out how to show different proposals with storyboards. On the ipad you can view storyboards and layers, if i could assign proposals to storyboards that would be ideal. Any thoughts?
That can be done by creating different Scenarios. Under the Present tab, it's the first button.
I can create a scenario, however where do you specify which proposal you want to use in the scenario?
Good question. I see where you can link it to the Storyboard. Konstantin (Autodesk), any suggestions?
When you are publishing a Scenario, the active Proposal is used to create it. There is no direct link to the Proposal from the Scenario itself. If you need to tie together a Proposal and a Scenario use a naming convention to do this.
I concur. Having some checkboxes to include proposals like you can with storyboards when publishing would be nice.
On second thought, Having to publish multiple scenarios to see different proposals is a lot considering each scenario is a separate file on the ipad's application. What would be better is to be able to specify the proposal you want to see on the story board.
