InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Sketchup Warehouse to AIM
7 REPLIES 7
Message 1 of 8
BrianHailey
2077 Views, 7 Replies
So, I followed the steps HERE to bring in sketchup buildings into myAIM model but the problem I'm having is the image that is a part of the sketchup file is coming in as well. If I go into 3DS Max and remove the image, the fbx file still has the image and I'm not sure how to get rid of it. Any ideas?
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
7 REPLIES 7
Message 2 of 8
BrianHailey
in reply to: BrianHailey
Aha! I figured it out! All by myself! And I'm not telling!
Ok, I'll tell. What I did was to erase the image out of 3DS Max Design, and then, instead of using the Export command, I selected the objects in the model and chose Export Selected. Worked BEAUTIFULLY! http://screencast.com/t/sEQZq5Kl
GEI Consultants
My Civil 3D Blog
Message 3 of 8
lholland
If there were a AIM wishes page, I'd add a wish to import a SKP directly.
Message 4 of 8
BrianHailey
in reply to: lholland
Fortunately, most people that will be using AIM have the Infrastructure Design Suite so they have 3DS Max as well. There is a plug in available in the AutoCAD Exchange that will import a Sketchup file directly into AutoCAD but I was having odd results with that. The 3DS Max route seems to work best for me.
GEI Consultants
My Civil 3D Blog
Message 5 of 8
And you should be able to "send-to your current 3D model" from 3ds max directly to AIM:
  1. open your AIM model you want the 3d model imported into
  2. select the 3D model in 3ds max you want to send-to AIM
  3. select the 3ds max application icon at the top left and then select "send-to AIM"...
  4. the model should then appear "magically" in AIM, where you can configure it and place it interactively
Konstantin.B
Software Architect
Message 6 of 8
That worked really slick. I'll have to try it again with the file with the image and see if I have the same issues (I'm assuming I will because it probably just automates the export everything to fbx command).
GEI Consultants
My Civil 3D Blog
Message 7 of 8
sconrad77
You can open .skp files using Sketchup Make (Free download) and export to Collada .dae or Autodesk .fbx.  These files work great in Infraworks, just import into the Style Pallet.
Message 8 of 8
BrianHailey
in reply to: sconrad77
Honestly, I just downloaded Sketchup and use that to convert them to the collada file format now.
GEI Consultants
My Civil 3D Blog
Rail Community
